beeping but no warning light
Hope someone can help
Ihaver noticed in the past 2 days a beeping noise (usually when cornering quite hard) but no warning light.
It's not the temperature dropping below 5 degrees (that worried me for ages in the winter until I realised what it was) or low washer fluid.
The beeps are quire drawn out and they happen 2 - 3 times then stop.
As I said it only happens when cornering quite hard, traction control is activated but does not cut in.
Anyone help please?
Quite possibly the coolant level sensor. If it did it while you were standing still, I'd say it was faulty for definite (quite common). But as you say it happens when you're cornering, I wonder if you're genuinely low on coolant?!
Check brake fluid level.
thanks guys
I'll check both tomorrow
