Rear Skoda badge
Just a quick one my fellow Briskodaians. To remove the rear skoda badge on boot lid. Is it just a case of warming it with a hair dryer and gently help it off? Mines a bit corroded and needs sorted as it looks a mess when rest of car is clean.
Yep just warm it up and prise it off with a credit card type card or/and fishing wire/dental floss to help it on its way. Then clean off gunk and polish up.
Just a quick one my fellow Briskodaians. To remove the rear skoda badge on boot lid. Is it just a case of warming it with a hair dryer and gently help it off? Mines not a bit corroded and needs sorted when rest of car is crap.
Edited by ramonford
lol is there holes there behind the badge? If not I'l leave it off, go for the minimal look.
Yep there's two small holes - so you'll need filler and spray if you want to leave it off :thumbup:
i also found once warmed up that it was easy to push the 2 platic clips out from inside the boot but it means removing the plastic cover inside the boot lid.
i replaced mine with a different badge.
then changed my mind and covered with another till i could get the holes filled and painted.
now i'm getting rid will leave this one on :thumbup:
na will stick it bac on. If the boot is slammed and cracks the filler it'l look a right chavy mess.
