5w40 Vs 5w30
Is there any benefit of using 5w40 to 5w30 engine oil or visa versa?
I am coming up to a 50k service and will be replacing the oil on the normal service intervals :think:
I will be probably going for this 2047.jpg as i am a mobil 1 geek :blush:
If you're going to be chaging it annually, not really!
The important thing is that it states VW502.00, 503.00 or 507.00 on it. :thumbup:
Go to skoda just over £20 for 5 litres of fully synthetic., it's 5w40 . Dealer told me it's what they use in all standard services, including cars which used to be 5w30
Good call. If you can get to TPS branch its about a fiver cheaper again, and really does the job well enough, pointless spending silly money on oil when the Quantum stuff is more than capable
You might get better MPG on 5w/30.
Thanks for the replies...........
How would i get better mpg?
5w/30 has a lower viscosity than 5w/40, Thinner oil, less friction,Engine warms up slightly quicker,better mpg. On the other hand some drivers prefer 5w/40 if they drive their car hard,Less topping up between oil changes.
Edited by roman.w
Its running on 5w/30 but I may give the 5w/40 a go to see if it makes much difference. Thank you :thumbup:
I drive my car on the track and use Castrol 10W/60, very good oil but a bit pricy
5w/30 has a lower viscosity than 5w/40, Thinner oil, less friction,Engine warms up slightly quicker,better mpg. .
If there is less friction, why would the warm up quicker? Surely the reverse
