Cleaned out my airfilter for the first time in 40k
bmc airbox
never ever cleaned. well hoovered out once
cleaned it with air filter cleaner...
holy balony what a nick it was in...
car feels 10x quicker
and you can actually hear an induction note now, its sucking like mad. well worth the effort :giggle:
wrong forum.... fabia 1 oooops :'(
Edited by BigJase88
moved :D
I cleaned my k&n panel the other day after 5k and it had 27 wasps/bees, 3 flys, 4 feathers and alot of muck. The car felt quicker like you said once i cleaned it.
yeah times that by 10... i nearly had a hive of wasps, it was filthy!
i used foam air filter cleaner, its the business, should clean it about 5 times i recon, better than those fluid filter cleaning kits
I need to do my BMC soon, although I doubt it is too bad as I cleaned it pre-rebuild, so has only done about 6 or 7k.
Where did you buy the foam cleaner from? I have a green panel filter which I should really give some TLC to.
What are you menna use to clean them? With my panel filter it i just used fairy liquid and blasted boiling water through it. Seemed clean enough, them sprayed it with that special oil stuff.
its proberly only a detergent thats in the filter cleaning kits anyway
Foam cleaner
better than the fluid imo!!
i never re-oiled it though as i didnt want to screw the maf sensor :thumbup:
