Service...
Gonna get the old man to change the oil on saturday, apart from the oil filter what else should I change? I know theres one part related to the oil but cant remember the name of it.
I've changed brake pads last month, changed the air filter, MAF and spark plugs about 4 months ago. Cleaned the TB out a couple months back too.
Is there anything else that needs doing?
Sump plug and seal?
Also you might want to change the fuel filter and pollen filter
Why should sump plug be changed?
You can get away with using it again once but even then it won't seal properly. You replace the whole thing as that's how it comes. You don't jus get the washer. Be careful not to over tighten it neither. Using the old plug also means you need to toighten it more than it should be to seal ot as its used and the washer is compressed slightly.
Plus its only like £1
Billy
