Flat spot
Hi
I,ve had a flat spot for a while now on my 52 reg VRS
I,ve had it re mapped but it had the flat spot before I had it re mapped.
My car will accelorate and at about 2 and half-3,000 revs it will die or just stop pulling and then she,ll pull again???
Can anyone help please, has anyone else had this problem with there,s
This is quite common, sounds like a split pipe, I have just solved the same thing on mine, have a read of these:-
http://briskoda.net/forums/topic/159278-i-know-it-has-been-covered-before-but/
http://briskoda.net/forums/topic/171771-some-really-good-news/
the best thing to do is clean all the pipes up with brake cleaner, go for a drive 5-10 mins and have another look and you should be able to see if there is any new grime on there which pipe is leaking. Good luck
Which hose is that m8? I,ve not looked at mine yet but I,ll have a look round it tomorrow but sounds like it could be the same pipe as yours with exactly the same problem
Thanks for the info m8
I,ve just noticed page 2 of your post where you explaine which hose lol, Doh. Cheers pal I,ll have a look tomorrow
