Airbag ecu
Just wondering If anyone has a airbag ecu for sale that will fit my fabia 1.9tdi elegance with part number 1c0 909 601 C. Or if anyone knows whether a ecu with the number 1c0 909 601 will still work or will it need coding or something? Any help appreciated :)
What's happened to the current unit? It might be something you could get repaired.
The new unit should have a letter code after it but all new or used ECU units will need coding to the car. I had mine repaired by crash data and as it was a repair it didn't need any recoding just plug back in.
drove through a flood a while back (bit silly of me) an water poured through the bulkhead on top of the unit, had it on diagnostics which says its buggered, so definatly need a new one :( cant find any used ones with the exact same number, only ones close are missing the letter of the end. but will they stil work?
