K04 Turbo upgrade...
Just looking into this really, at the moment I have a completely standard 03 VRS, if I wanted to upgrade my turbo to a K04 turbo what exactly needs to be replaced and upgraded at the same time??
If someone can help me draw up a list of what needs to be changed to make the most of the upgrade I'd be hugely grateful :D plus it will help anyone else who may be interested in doing the same.
have a search matey, best way to start!
I'm doing that at the same time, just making sure I don't miss anything out lol :)
i wont try to tell you what turbo, ko4 isnt much of an upgrade for the cost however, ko4 or even k03 hybrid is a nice way forward.
turbo, manifold, downpipe, cat bypass or sports cat to uprated exhaust, injectors, 4bar fpr, new map, suspension and brakes to handle upgrade..am sure there is more, thats a quick list
Theres all the oil pipes and feeds to sort with the k04 aswell, think the k03s hybrid is the cheapest and easiest option out of the 2?
yes and it seems to yield very similar results.
Hello, DanBoy,
I also have this in mind, but I already have all the parts (in a box, not yet on the car).
The parts should come from - Audi TT 225, Leon Cupra R, S3 - engine code BAM (or AMK)
This is what you will need:
- k04-02x turbocharger (mine is k04-023): 06A 145 704 Q or QX
- turbocharger gasket (turbo to manifold): 06A 253 039 H
- turbocharger gasket (turbo to downpipe): 8L9 253 115 A
- coolant hose gasket: 058 145 757 A
- coolant hose gasket: 058 145 757 C
- hex. bolt: N 010 217 10 (2 pcs.)
- hex. bolt: N 014 702 10 (2 pcs.)
- threaded pin: N 907 678 01 (3 pcs.)
- banjo bolt: N 021 071 7 (2 pcs. - more might be needed)
- banjo bolt: N 021 074 2 (2 pcs. - more might be needed)
- o-ring: N 013 812 8 (6 pcs.)
- o-ring: N 013 814 9 (4 pcs.)
YOU MIGHT ALSO NEED THIS. I DON'T KNOW FOR SURE YET:
- coolant pipe: 06A 121 492 M
- coolant hose: 06A 121 497 P
- exhaust manifold: 06A 253 033 AJ
- exhaust manifold gasket: 058 253 039 L
- exhaust manifold washer: N 903 572 01 (13 pcs.)
- exhaust manifold shouldered hex. nut: N 902 002 01 (13 pcs.)
- exhaust manifold head bolt: 06A 145 540 K (3 pcs.)
- exhaust manifold washer: 06A 145 791 A (3 pcs.)
- injectors: 06A 906 031 BC (4 pcs.)
- o-ring: 035 906 149 A (4 pcs.)
- o-ring: 06A 906 149 (4 pcs.)
Note that you will also need a custom downpipe (70mm recommended) and/or exhaust.
You will also need a FMIC (front mounted intercooler), as the standard SMIC is too small for this setup.
Most importantly you will need a custom remap. Some remaps need a 4 bar fuel pressure regulator: 078 133 534 C.
You will find a useful guide here:
http://forums.vwvort...ead.php?3562254
Good luck!
Edited by Devil69
above is very good info but as you say its bog standard you will also need
3 inch maf
bam tip pipe
modified or bam airbox
uprated suspension
uprated brakes
lsd to get power down
catch can setup to stop oil contamination
uprated dv
poss rear arb
s3 lower strut brace
lots and lots of money
etc etc etc
the list goes on
why not spend a few £££ and ge the k03s actually working lol
if not happy then go for k04 but doesnt give that good a gain realistic 260 to 270 bhp
k03s hybrid realistic 270 to 280 bhp
a pushed k03s 235- 240 bhp
or go the full hog k04 hybrid seeing 300+ with minimal lag
Thanks for all the feedback, gives me plenty to look into there :)
Probably a bit of a silly question, obviously I've got a K03 turbo, whats different with a K03 hybrid? just so I can try and understand it all lol :D
You have a K03S, a hybrid version is one that has been modified to produce more basically.
i am no expert...wait for clive to reply, he had a cr turbos one, they iirc use ko4 internals inside the ko3s housing.
Put it this way, since i have had my car, i have been planning a turbo change, and have gone from vf34 to gt2860rs to hybrid ko3 to hybrid k04 to holsett hybrid.
Under no way however would i bother putting a stock ko4 on, its just not worth it for the money, if you can afford that, then get the ko3s hybrid which will be a lot less effort and work to fit and offer better figures than a stock ko4 or go the full hog and fit a ko4 hybrid.....or go full on big turbo..
Ah brillant, thanks for the help so far :D
As your in Northampton pop into Unit18 and have a word with Ali, sure he can sort you out with some good upgrades.
I'll look into that, I can see myself spending loads of money but its all worth it.
Good idea, he can sort the mapping etc aswell that you would need.
yep you is correct :thumbup: although sometimes it seems to be hit and miss to what parts they actually use lol
i agree 100% no point fitting standard k04 imo
plus 1 here for the ko4 hybrid the normal ko4 just dont cut it ,just pm me bud if you need any help :thumbup:
what kind of figure does your ko4 hybrid produce, what other mods do you have stig1?
4 bar fpr ,305 fuel pump large fmic , uprated intake , metal renforced intake pipe , 3 inch turbo back stainless system ,custom map solid flywheel lightened and balanced 304 bhp and happy with it now
awesome figures nice one, i bet you are happy with that B)
how does it compare with oe, do you suffer any lag or slower spool over standard?
assume you have an aftermarket exhaust too? cat bypass or sports cat?
yes like i said last post 3 inch from the turbo back , its got hardly if anymore lag than a stage 1 ko3s car , the only thing you have to watch is the torque steer but apart from that it s wicked very happy with the car :D
doh lol,
so cat or not?
which hybrid you have?
atb/lsd?
ha ha like i said turbo back so no cat , no atb or lsd cant afford it at the mo , but really does need one
sorry its a CR turbo s hybrid
cool cheers, wasnt sure if you had a sports cat maybe.
Yup drove a friends car with an atb fitted (another vrs) and although mine handles well since i fitted all the tt/r32 stuff, the quaife just cant be described, its awesome!
Sounds good buddy :thumbup:
