Octavia spiders. Do brembo's fit below?
Im after some octavia 17" spiders to go on my fabia vrs
Im running the brembo gt kit (323mm) same as the leon cupra r set up!
Will octavia vrs alloys fit on without spacers??
No
the guy i bought my brembo kit off of had vrs spiders and he supplied in the kit 15mm spacers which was what he was using. Not sure if that much is required, but on my current alloys and the set i had before these which were after the spiders all required 15mm spacers to fit.
Balls
run spacers?
ally ones are fine
how much did you pay for spacers Luca? as I am going to be fitting Brembos (when I get hold of a matching caliper :D) but on the 4x4 with 17" spiders
alright Karl, well i had steel ones, but being a tart i wanted ally so found a guy on ebay who did me a right deal and were not expensive at all, will find his details and pm them to you when i get a chance.
What brembo do you have so far, did you sort out carriers from graham?
got a caliper form an Alfa 159 and the carriers from Graham to fit to 312mm disks, found a supplier that can do the other caliper for around £100 but got to wait till they have stock :-(
