u like?
69 members have voted
  1. 1. u like
    • yes
      68%
      47
    • narrr
      31%
      22
Please sign in or register to vote in this poll.
Nicely done, cheers :thumbup:
I'm surprised you don't like Rob, I think they would compilment your wheels/mirror covers perfectly. :yes:
Yes, you're probably right.
They do look good, but its a bit like the car is wearing sunglasses - cool, but a bit silly at night time.
:p
:p
I will convert you when I post my pictures! :thumbup:
Having said that, they will probably suit the a black car more so than white.
Look forward to those pics
+1
lets see them
:thumbup:
Also did you order a cutting implement? How easy is the cover to cut and follow the shape of the headlight? The FL light is a harder shape to cut to I would imagine?
I did order the cutter, I haven't got the film yet (I would not expect to it this side of Xmas) but the small piece I used on the DRL's was easy to cut with a scapel, I agree re: the FL light the pre-FL should be a piece of cake. :thumbup:
Famous last words! :doh:
Yes did them myself after work, took 30mins. Its the "SubtleGrey" from Lamin-x, very easy and good mod. I also done the fogs but not LEDs yet.
How easy were they to doon the FL light? Did you order the cutter?
Had my subtle tint delivered today. Ordered 16" x 12" in the end but don't believe I'll do it with one sheet. How
many sheets did you use Mobov? Or is the sheet more flexible and and can be pulled out a bit?
What are you planning to cover with that sheet?
Headlights on a FL
I got two sheets and yes, I ordered the cutter. It was very easy although you can remove the lights and do it indoors. A heat gun or hairdrier is a must!
Nice one I'll get another sheet , what size sheets did you order?. Did you peel the sheet off and cut it on the light or measure and cut it on the cardboard paper? Does it stretch a bit with heat?
I heated the film, applied it all over and smoothed out, then went round the edge and cut. Then peeled the edges off, try to cut round in one go. Cant recall what I ordered but it might have been the biggest sheet. Also youtube some vids of it.
