IS IT TRACTION CONTROL?
SET off today in the wet rather briskly and the wheels began to spin then there was a quick noise from the front end like a hammering on the front end is this the traction system sorting things out, had this on a rover 216 twin cam when you spun the wheels badly enough only in the wet ,like the wheels are jumping, any ideas anyone cheers
Yup. And you will get through your tyres pretty quickly using that much accelerator from a standstill.
cheers it will be worse after the shark remap then, it must be when wheels are spinning at different speeds i had a bit of lock on
sounds like axle tramp to me..
Like
