ignition wiring
i am planning to 'play' with the wiring of the nova a little bit and would to know other peoples opinions on the connections on the ignition. are my guesses incorrect?
sorted it via a vauxhall forum, goes as follows
Red - Positive 12volt feed to ignition switch
Thin Black - Energised with key at "I" position
Thick Black - Energised with Key at "II" position
Black/Red - Energised with key at "III" position (May be one or two wires)
Which one lights up the neon washer jets then ? :D
:finger:
i hate those blasted things, i have fitted a keyless start though :D
press the on switch for the ignition to come on then pres the starter buton to start the engine :)
Well, all of them, obviously........
Phil ;)
:finger:
i hate those blasted things' date=' i have fitted a keyless start though :D
press the on switch for the ignition to come on then pres the starter buton to start the engine :)[/quote']
I thought all Novas had a keyless start?
Admittedly it usually involves the use of a screwdriver....
:D
ah but mine is all proper like, well as proper as me butchering other stuff for switches and buyng a random push to make switch can be called proper
