ash tray bulb
hi people
Does anyone out there in skoda land know how to change the little light bulb in the ash tray. I'm sure there should be one, because in the removable tray theres a litte window.
cheers Rich
If you look in the tray holder, you can see the bulb on the other side of the hole that lines up with the window when the ashtray is open. As this implies you have to remove the ashtray holder to get to the bulb.
Remove the trim below and above the ashtray to reveal the screws. Undo the screws and remove the ashtray holder. The bulb is clipped to the underside.
IIRC, the bulb is embedded in plastic, so you need to get it from the dealer
Edited by rwbaldwin
