Engine Oil
I'm currently far away from any authorized Skoda/VAG dealer/mechanic and I need to top the engine oil before I make the trip back home.
According to the user manual the specs for my engine are:
1.6 ltr./75 kW - EU4, EU2 and uses oil graded VW 501 01, VW 502 00
What is the SAE equivalent to it?
Is there any conversion table?
I tried googling it and came out more confused than when I started so any help would be greatly appreciated. emoticon-0124-worried.gif
Try putting your VRN in on HERE and see what they use? :thumbup:
EDIT: Used a british vehicle with the same engine as yours and it says to use Castrol Edge 5w30 (fully synthetic). Hope this helps :thumbup:
Edited by skoda norm
Thanks skoda norm. It seems to be right, I found this equivalent oil list on a brazilian VW forum. The only ones available around here right now are the last two, so I'll be using one of them. Thanks a lot.
CASTROL TXT SOFTEC 5W40
ELF SYNTHESE 5W40
ESSO ULTRON 5W40
TEXACO HAVOLINE FORMULA 3 SYNTHETIC 5W40
IPIRANGA F1 MASTER SINTÉTICO 5W40
IPIRANGA F1 MASTER 502 10W40
PETROBRAS LUBRAX SINTÉTICO 5W40
MOBIL 1 0W40
MOTUL 6100 SYNERGIE 5W40
MOTUL 8100 E-Tech 0W40
MOTUL 8100 X-Cess 5W40
PENTOSIN PENTOSPEED 0W30
PENTOSYNTH 5W40
SHELL HELIX ULTRA 5W40
SHELL HELIX PLUS 10W40
The VAG oil spec number should be on the oil container label, for example VW 502 . You should always check for this number on the container.
