Remove front door speeker panel?
Hi, have removed the 4 screws at the bottom of the dor, but cant get the panel off. Se the window handel (no electric windows), cant get it off. Any ideas about how to remove it, or is it something else to remove?
thanks
The winder comes off by pushing the slide out at the back of the handle. The door handle / rest cover has to come off to reveal more screws.
Edited by moley
The cover over the mirror adjuster also has to come off and the rear torx screw needs removing.
I believe the actual speakers are riveted in so will need drilling.
Edited by anewman
On mine ('54 plate), it's screwed in (I checked with TPS before I got the replacement speaker).
Here you go...
There are 3 chunky crosshead screws within the armrest handle
revealed by removing the top 2 sections. (Smaller one first then larger)
and a tiny torx screw which is very easy to drop behind the
electric mirror control stick panel (if yours has these??) If not then I'd
imagine theres a small blanking panel like there is on the passenger side...
More info which may help here...
http://www.fabia-vrs.com/technical-info/door-carrier-repair/
and here...
http://briskoda.net/forums/topic/96959-diy-door-sealing-tutorial-costs-less-than-l10/
:thumbup:
