Drop Link Problems Again Argh!
Righty ho ,
Got the infamous knocking noise in the early summer (june) and as i was away on holiday didnt get them fixed until August , Got my local garage to fit me new ones , and as he is a nice guy let me help out.
About 4 weeks ago they were shot, knocking agai :thumbdown:
After seeing it was a relatively easy job to do , bought a new set from Andrew Watt auto stores for £20 and fitted them in an hour , was well chuffed , job well done B) or so i thought ....
Today on the way home from work approaching a roundabout heard the knocking noise again! and after rocking the car , its the same knocking as before :'( :'(
Any thoughts?
Apparently mondeo ones seem to be a common fix... but theres also a company that does strengthened ones....see if i can dig the link out...
FABIA (6Y2) 1.9 SDI Stabiliser Link Supplier Meyle Part Number 1160600000/HD
I cant put in a direct link unfortunately due to the way the site is built...you just need to input your car info then scroll over to Steeriing & Suspension > Steering & Susp Components > then search for the above part number...£11.66 ea.
HTH
Danny
Are you sure the nuts are tight, if they have slackened off a bit it will give the same noise as a duff drop link.
DB.
Did you solve your problem, were the nuts slack ?
DB.
Just resolved yesterday mate , the plastic lockring on the nut had snapped , so just replaced all 4 nuts and has solved the problem :thumbup::D cheers for the help :)
