Removing trim around rear screen Brake lights
Does anyone know how to remove the trim around the high level Brake light (07 Vrs Hatch). Mine is full of white bits and other rubbish, god only knows how it got there in the first place. I've had a look at it but it looks to be glued on. How do you replace the bulbs if they blow.
Auric
The high level brake light is a one piece LED bar so there are no individual bulbs to replace.
This could be why Skoda haven't made access easier / more obvious as it is likely it would be a dealer fix if it failed.
Sorry, can't help you on how to get into it but I'm sure there will be a way!
