Audi A4 seats...
Will Audi A4 front seats fit an Octavia, or will the runners need replacing / modifying?
The A4 is a different floor pan, so you would need to modify or replace the runners at the very least.
The seats may be wider too, so might not fit at all.
they will fit width wise, but require custom frames, not really worth it unless you can fabricate them yourself or get the seats really cheap, why not look at a3 stuff instead that does fit,
Thanks for the replies guys.
I'd love Golf R32 seats, but they're too expensive - I just want decent Recaro's as the standard vRS seats arent as supportive as I've like.
Check seats from the Bora....might have better luck there.
You have PM
Are seats from a GT TDI Golf heated? I have seen a set (front, rear & door cards, etc up for grabs). I fancy some better seats, and it would be nice if they would warm my backside on these cold winter mornings.... :smirk:
Only if it came with leather or was specced from new with the winter pack I think.
I had a 54 plate Bora Sport which is basically the same thing and the seats in that weren't heated. If you can find a Bora HighLine, they had leather sports seats with heating.
Checked with the seller, they were from a 2002, and not heated. If I were to change the seats I think I would plump for heated. Not too sure if I want leather seats as I quite often wear shorts in the car in the summer months.....
I just picked up a set of A3 sport leather seats, they fit just fine!
