pd150 turbo
could someone please confirm if the pd150 turbo has the part number gt1749vb
need it confirming asap please
many thanks ste
Yes that is the one.
thanks very much fella
hopefully will be buying one tomorrow :)
Good luck mate :)
what sort of power gains would you expect from a hybrid pd150??
say a ball park figure? would 220 be abit ambitious?
hybrid 220bhp - up to 230 with other complimentary mods, stock around 190.
gathering the bits at the mo so i can throw everything on in one go so to speak
im thinking hybrid pd150
ss front mount
egr delete
turbo bk exhaust
and custom mapping
anything else i should add to the list?
Uprated clutch may be in order..
yes good shout can i just run the original clutch and flywheel untill they give up or is it not recommended
You may have to limit the torque, on the standard clutch otherwise you will need one sooner rather than later.
well as soon as it gives up ill be upgrading accordingly will it do any damage to the engine if the flywheel gives up. i know they make a right rackett when they on there last legs
If you build a 220hp+ car and keep oem clutch, I wouldn't use more than about 75% of the power until you get a new one in there. I think it would start slipping p.d.q. ;)
well bought the pd150 today for £210 delivered has come off a 41k car but guna rebuild to make sure of reliabily anyway :) let the games begin
If your not hybriding it, it'll only cope with 190/200bhp.
Matt
Go for big power, I'm at 240 and want more
Hybrid pd150 220-230 tops
Im running a hybrid vnt20 on my pd130 golf its mahoosive
Wanna crack 300 horse
Diblias cam
Race injectors
Pwr charge cooler
Water meth
Mmmmm boooost
Part number for the hybrid turbo?
Does hybrid / pd150 require any internal stuff etc or is it a straight swap?
Clock the housing (few bolts)
Then bolt straight on
