condensation in headlight
do you think its warranty ???
bump
it should be, but i had the same problem although not as bad as yours, check the grey cover over the back of the lights is fully inplace and snapped on snuggly, mines wasnt in right and thus the condensation, to fix i removed the back light cover so the condensation could get out, i then switched on the light full blast to generate heat so i could evaporate the condesation off, i also used a hair drier which i moved accross the front of the lens to speed up the evaporation,once the condendstion ewas gone i refitted the cover properly.
good idea shall try that at the weekend :D
Yup, I also have this, same light, on my 7 week old vRS. I'll also check out the seating of the rear cover at the weekend. (Hopefully when I will also be fitting my SEAT Strut Brace :thumbup: )
nice mod the brace :)
This isn't a result of you driving through rivers the other day is it? ;):D
Chris
Chris
who said that what what !!! who knows tbh :(
Scubi gear on a Furby, whatever next :rofl:
Yes, I has mine done a few months ago for less condensation than that.
well least its a known problem :)
Same lamp went on mine. Xenon lamps on mine so not cheap. But after a bit of argument it's going in tomorrow to be fixed under warranty.
