left dual zone climatronic dial light flashing
When I start up the car, the left climatronic light has started to flash. Any idea why? it is the light around the bottom left dial, see below.
thanks,
Stuart
Perhaps the LHS dial is set too cold or too hot to be within the automatic range?
Nothing I can spot in the manual re. flashing lights.
it tend to notice it when I have it on full heat to warm up the car from start.
After being in my car, I deduce from your picture that you have heated seats. Maybe a fault there?
If the climatronic is set at full heat, it will be out of the range of automatic parameters. Leave it at 23°C and see if the light still flashes. AFAIK the heat does not appear any faster if the dial is turned up to MAX. It is automatic after all.
Sorry but I can not think of anything else at present.
Edited by gregoir
