felicia pickup
Hi
Can anyone of you tell me the correct term for the plastic trims that go along the sides of the felicia pickup truck ?I have been trying to locate a pair but the only name for them i can come up with is "HOCKEY STICKS",Also can anyone give any clues as to where i might buy some !!!!!!!!
thanks in advance
Usually known as rub strips/bump strips on most cars if you are talking about what im thinking :thumbup:
I think i explained wrong ! the parts i mean are the plastic covers that go on the top of the side panels on the pickup,mine has been a cube van and where they should be the removable back would have been sat on the side panels so as to not require them
Skoda's part name is "protective strip" - exactly the same as for the door/side panel ones, unhelpfully. I don't know if they're still available new, but VAGcat seems to suggest they'd be around £150 each if they are. :o
OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :o .Looks like ill have to put the top back on it.Thanks for your info
that sounds about right, about £130 each, and they are no longer available to buy new from skoda along with most of the other body panels
My pick up was a cube van in a formerr life! I painted the top face black and bought some edging trim from ebay for 15quid or so. I'll send a link over the weekend, got to go to work soon.
I know the back one was about 70quid when I de spoilered my Fun.
just for reference, the side ones just pull on/off and they are really tricky to get off without bending them.. the one on top of the tailgate is bolted on from the inside, you have to remove the cover plate from the inside of the tailgate to get to the nuts
Any tips on how to take them off? (pull which way etc)
Ta.
Alex
just work your way along carefully... we rang for some the other day and couldnt get any...not that id of paid £150 a side!... then as we were on our way to brid we nipped into an old style scrap yard on the off chance and gained a set of hockey sticks and a tailgate and all fittings for £30 i nearly kissed the guy!
