Cheap ISO lead for octavia 1 and some info on installing aftermarket HU's
Just a heads up really if you are considering fitting a Head unit in your octavia/Fabia 1 and require an ISO lead
I found the product code PC2-69-4 for octavia 1 + Fabia 1 ISO leads selling at halfrauds for about £20! :o
a Seat Toledo aftermarket one using the same product code is £2.88 with free P+P here http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150391438228&ssPageName=ADME:X:RTQ:GB:1123
have dealt with the seller liquid ICE in the past and they were spot on :thumbup:
Also it seems a little bit of a grey area people fitting aftermarket HU's in the octys and other VAG cars due to fear of putting Constant 12V down the K-line use for diagnostics. Some are fine and others aren't so sure
found a little explanation and test here if you were maybe put off by it.
http://www.ross-tech.com/vag-com/aftermarket-radio.html
Thought these might be of use and could save a few quid in future!
HTH,
Lew
... halfrauds ...
+1 :wonder:
Good find on ebay
TBH, I'd save myself 2.88 and cut the extra connectors on the existing iso block :giggle:
Think you'd still have to mess around with ebay iso block, as it may require a power line to the aerial amp
Checking the wiring of the iso should be 2nd nature away - many manufactures seem to like moving things round - swapping of the ignition and battery 12v power wires is common :dull:
Don't think I've ever fitted an iso block with having to fiddle with one of the connections
Edited by snow_muncher
