Central locking 'Anti-hijack'
Hi,
I pick up my 2009 VRS LE on 20th and am wondering if you can set the anti-hijack on the central locking from the maxi-dot or if i need to get the dealer to do it for me?
Nathan
Hi,
Nathan
You should be able to set it on the maxi dot.
It's under convience and is the auto lock and unlock settings
The ability to alter this function has become available on later Maxidot revisions. I'm just not exactly sure when. As the LE is effectively a hybrid of some newer FL features and the older body style, I reckon it will be available to you. Worth checking through the menus while you're still at the dealers though :thumbup:
Otherwise a VAG-COM/VCDS equipped member near to you would be able to kindly adjust it :yes:
Cheers,
Steve
