knocking tappets in 1.9TDI 110
Hi does anyone knows how much can cost replacing hydraulic tappets in 1.9 TDI ASV? Can you reccomend any good garage/mechanic in derby/nottingham area? Someone who knows tdi's engines very well?
Edited by lukanio63
Maybe Greg123 (?) does this kind of thing. He's based in Notts.
http://www.small-engine.co.uk/
Not sure that Greg123 is still on here, but contact him via the weblink in post #2.
I've recommended him to folks in the Notts area on numerous occasions and he's always done a first rate job.
Try an oil change before panicking about the tappets.
Oil was changed about 4000 miles ago for mobil 1 0w40.
are you on variable servicing? 0w40 isn't standard spec oil...
I spoke to Greg yesterday, he is still very much alive and kicking, give him a call :thumbup:
Yeah, as far as I can tell for ASV (insofar as it's NOT AWX/ATD/AVB!), Autodata says 15W40 or 10W40 semi-synth. Should only be 506.01 0W30 spec for variable servicing...
HTH
Are u sure its not a sticky tappet? Had it happen to my car for a day or 2 then it freed its self, and has been fine since.
