what sort of power can i expect from a stage 2 remap
what power can expect from a stage 2 remap with s3 injector and 4 bar fuel pressure reglator cat back 2.5inch exhaust amd cai
well injectors are pointless as there not needed
to go stage 2 you will need a
TIP pipe
downpipe ( as that the resriction the cat back does nothing )
frontmount
dump valve
and put the 3 bar fpr back on 4 bar only needed with jabba map i think
then you can go stage 2 otherwise yours is just a stage 1 about 210bhp
TIP pipe
frontmount
dump valve
I have a 4 Bar FPR with my stage 2 revo from JKM
okay its revo i know one of the tuners likes a 4 bar map
sorry forgote to say turbo tip and down pipe and 007p recirc valve
and 4 bpr is handy to have and as for injectors there also handy to have more fuel to be pumped in means more power it was remaped with just a standard engine and run 212bhp and 214 lb
Edited by dannyboi
result does that mean if i put some 600cc injectors in i will get 300bhp from a ko3s as it would be putting in lots of fuel?????????
what about a high pressure fuel pump will i get even more?????
maybe this is where we have all been going wrong
lmao
With a stage two and a cat still in place mine made 221 @ the wheels/245bhp@flywheel and 279lbs.Now has a decat and does feel faster although some people on here may say thats impossible. :p
Just buy mine and save yourself alot of money :rofl:
Mine made 209 at the wheels with Shark Stage 2 map and decat.
Going to get it dyno'd again with the FMIC soon.
rob put some 1000cc injectors in !!!!!!! i recon you will hit 400bhp as it will put loads more fuel in wich =more power
