Air con
My Skoda Fabia Tdi 2002 has been having starting problems and the scan has highlighted a few issues
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 AF
Component: 1,9l R4 EDC 0000SG 1110
Coding: 00002
Shop #: WSC 13765
1 Fault Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 13765
VCID: 4280425364FD
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
VCID: F2E0529394DD
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25754
Shop #: WSC 13765
VCID: 3A703AB30C2D
1 Fault Found:
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 0004
Coding: 12338
Shop #: WSC 13765
VCID: 2044E8DB8AB1
No fault code found.
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y2 919 880 D
Component: KOMBIINSTRUMENT VDO V11
Coding: 16441
Shop #: WSC 13765
VCID: 4894507B42C1
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 13765
VCID: F0E4589B9AD1
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00110
Shop #: WSC 00000
VCID: 397225BF092B
1 Fault Found:
01288 - Terminal 30; Steering Assist
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 31 Komfortgerát 0001
Coding: 00067
Shop #: WSC 13765
VCID: 3D7A31AF1D03
Part No: 6Q2959802
Component: 31 Tõrsteuer.FS TFK 0002
Part No: 6Q2959801
Component: 31 Tõrsteuer.BF TFK 0002
Any ideas anyone
P
Well, forgetting the AIR CON issues for a moment, I'd reckon that you need to sort out the alternator load sensing wiring - use the search function to find out more about that problem. After that has been sorted out and you have now charged the battery up correctly, clear all stored faults, perform basic functions on the AIR CON and see if that sorts the AIR CON problems for a while, if not then you will need to start to think about replacoing some of the AIR CON flap control motors.
Cheers for that. I think the motor flap is draining the battery. I got a new alternator march this year as we were having to replace the battery annually. After not driving the car for a few weeks in September the alternator was replaced as it failed to start the car. AA advised it was faulty as still under guarantee the garage replaced it.
On 13th Nov the car wouldn't start so I charged the battery and the next day the car was starting fine until 24th - when I used the aircon to clear the misted front & rear windows. The ABS and transction control indicators came on as well as power steering light when I tried to take off. I managed to drive as when I turned off rear window heater the ABS and transction lights went out and a few mins later when I restarted the car the power steering light went out and IT returned to normal. I think the alternator code was generated from 23rd.
After the incident on 13th I ran the code search on 17/11 and all the same codes were the same except the new alternator one. At that time I cleared the codes but still aircon is a problem as from the latest code search on 24th
What do you think?
P.
As post #2, get the load wire sorted. Once the alternator is charging correctly then the electrics will have a chance of working as they should.
Yeah i'll def speak to garage about the load sense wiring. I've noticed that the air con on the two front facing window air vents at the driver and passenger side operate when the air con is off, and set to blow up the windscreen, so i think there might be an issue there too?
