Bolero Steering Wheel Controls or Stalk Controls
Hi Everyone!
Is there any steering wheel controls or a steering wheel stalk available to control the bolero system?
I know the DSG steering wheel has some controls but can this be fitting to a manual car?
Has anyone done this and how difficult was it to fit?
If you have maxidot then you can get limited use in controlling the channels/tracks etc via the right stalk.
I don't have maxi dot, is there any other after market product for this?
Try asking Ben (shark_90) in the Shark Performance section as his knowledge far exceeds his looks and he'll be able to tell you more about fitting a MFSW to a manual car. :giggle:
You can fit a DSG MFSW to a manual car, you just have some redundant paddles attached to the wheel. You could also fit a non VRS MFSW from a manual car but you lose the VRS detailing on the wheel.
Thanks for reply!
Is there any extra wire or wiring loom required when fitting the VRS MFSW?
Thanks for reply!
You'll need a new controller unit and a bit of new wiring to do with the airbag. Once swapped, there's then a bit of work with a computer to get it all working but basically it's plug and play. Swapping vRS badge from vRS wheel to non-vRS wheel is easy. I think you can only fit a 3 spoke wheel to a car with an original 3 spoke wheel and 4 spoke to 4 spoke, but I am happy to be corrected on that. I'd post some pics of mine if I were technically literate - but I aint :'( I went for 3 spoke in all smooth leather. I actually prefer the look and feel of it to the perforated leather so I'm well pleased with the change.
Sarge.
