Aero Wipers
dont know if this should be in my performance or maintenance as i'm not wanting to change them for a mod for mod's sake more that they need changing and i wanted to upgrade/change the wipers for something different/better.
So.
Where do i get them from, how much and whats the car they are made for or whats the p/n ??
Thanks in advance and mods feel free to move accordingly.
Probably been better in the Octavia section, personally, but here you go.
To get them, either brand new from a VW dealer as they were not fitted to the MK1 Octavia, or to a VW breakers yard.
The car you need would probably be the Mk4 Golf, although the Passat wipers might fit and even the current Polo. SKoda wise check out the Superb ones or even the Octavia Mk2 as they might.
Before you do anything though, measure the lengths of your wipers with the blades on from the spindle end of the wiper arm to the far end of the wiper to see how long you need.
The Octavia should manage a straight swap for it, unlike the Fabia, which needs to have the arms butchered.
so the aero wipers are the whole arm and everything??
i thought it would just be the actual wiper on the end...lol
i thought i read on here JHM Butts do them... anyone know?
vagparts or PM Stathap.
Areo wiper blades are a complete part (blade end..not including arm), which just pivot on a pin, and just slide on or off depending on how the blade is in relation to the arm...you would therefore need new arms as well.
2 new blades cost me
sorry to sound dumb but what is the advantage of these over standard?
They have a lower profile, but because they also have a rubber fin the whole length of the blade and no metal assembly they give a much better and complete sweep without any pressure lines as well as pressing better against the glass when at speed.
cool cool thanks for that
Further to the PM
To uprade to Aero's you will need to change the whole arm, blade and cap.
* Just the Aero WIPERS are not compatible with our existing wiper ARMS *
I got mine from
http://www.vagparts.com/
look under
Online Shop - Product Overview - VW - Gold mk IV - Exterior - Aero Wipers - Golf mk IV front Aero Wipers
Cost is about
Bosch sells a set since a month or two for the octavia. Which fits directly on our standard arms.
  • 4 months later...
FRONT
1J1 955 425A
1J1 955 426A
1J1 955 409D
1J1 955 410D
These numbers are only for cars with steering wheel on the left side!
REAR
1T0 955 707 A
6Q6 955 425 A
1Z9 955 435
Another Pics on my Nickpage...
Regards...Kromi
Not in the UK they dont :mad:
Thought I had seen a Bosch set in halfords may have been champion tho:confused:
I got the Bosch Aero's from germany. They are a straight swap. Don't need to change the arms or anything!
It's not the same!
There is an optical difference between the original aerotwins and the aero wipers you can use with the original arms.
Regards...Kromi
FRONT
1J1 955 425A
1J1 955 426A
1J1 955 409D
1J1 955 410D
REAR
1T0 955 707 A
6Q6 955 425 A
1Z9 955 435
Regards...Kromi
KROMI , some nice bits of kit in the pictures , where did you get the BOONRATH LIFTERS FROM and how much is the price , are they direct from Germany .
Bought second hand on ebay Germany for 50 EUR.
You also can buy the lifters on Bonrath or Milotec. They are the same.
Regards...Kromi
  • 2 years later...
Have just acquired some aero wiper blades and arms for my '05 Superb. But can I get the old ones off??? No I can't!
Have followed the above instructions as well as I can but they won't budge and I don't want to damage anything by using too much brute force.
Any more tips would be appreciated. Might I need some sort of puller?
Cheers,
Rob
Check the date guys, this thread is over two years old and these wippers were not available back then! The threads been given a bump :D
:doh::o:sorry:
It's OK guys, it was me who gave the thread a bump cos I can't get the damn things off my car!
(Still looking for advice!)
Cheers,
Rob
