Do I Need 3 Or 4 Litre Brakefluid When Changing It?
I "think" 3 is enough ... but what if my dealer "blunders" and need's a bit more. Maybe 4 litre is more on the safe side.. hmm :confused:
It all depends on what you are putting in.
If its DOT 5 and above you will probably need 4 or 5 litres to make sure the system is fully flushed.
If it is Super DOT 4, you'll be OK with 2 as it is compatible and the flushing isn't quite as critical. System capacity is only about 1.75l IIRC
It's Motul RBF 600 i'm putting in.. is that super DOT 4?
edit: NORMES : FMVSS 116 DOT 4 / SAE J 1703 / ISO 4925
Yep, its DOT 4, not sure if its the super which has a higher wet and dry boiling poiunt than the DOT 5
:D
