buying used vrs
Hi,
After the girlfriends purchase of a new vrs cr in may i am now looking at buying a used vrs after christmas. Probably an 06/07 petrol with hopefully less than 40k miles. Is there anything to specificaly watch out for in the way of faults or is it a case of just checking for the usual stuff?
Not sure I'd be happy about the GF having a nicer vRS than me!
+1
Its not too much of a hardship really as i can still get to use it if i want, just dont feel like i should cane someone elses car!
Think you misread it, his girlfriend has a diesel! :-)
Common Problems
-Check the ESP, an 06/40k example is ripe for failure, plenty of threads on this. (A big repair bill, get it under warranty)
-Water in the spare wheel well, popped off washer pipe, again plenty of threads.
-Seat airbag wiring loom, can be either side, dodgy connection causes fault.
I believe some have had problems with uneven tyre wear and sawtoothing, cant say Ive had that.
Common Problems
Is esp standard on an early mk 2 vrs?
+1. If you buy a petrol vRS, you'll have the bragging rights!
I believe it was established in another thread that it was. :yes:. Think it was optional on Mk1
http://briskoda.net/forums/topic/180386-esp-abs-issue/page__st__20
halfway down
also to an earlier point all M2 VRS had esp as standard, still got the brochure :thumbup:
Edited by Rhoobarb
looks like i will just have to budget for a replacement should it fail, if i buy a car privately it should be around £800 cheaper than from a dealer, dealer car will have 12 months warranty so its swings and roundabouts. Anyone know if the leon cupra/ fr comes with the same set up?
It affected a lot of cars across the VAG range as well as BMW and Volvo.
Dont let it put you off too much, the Octavia VRS is a cracking car and excellent value for money. I think if you asked most users on here would agree..
Edited by Rhoobarb
