Next level of Tune
At the moment i have the following list of upgrades
MOMO strut brace
White line RARB
Eibach pro springs
312 mm Audi TT brake upgrade
PD160 intake
Piper cross panel filter
Custom FMIC
Wide mouth mod
Celtic tuneing remap to 182bhp 302ft-lb
So with the above list am i right in thinking i need the following
Uprated Clutch
Hybrid Turbo
Singal mass flywheel
then a remap once all is done but im just not sure on a few things so i was hopeing you guys could point me in the right direction with the following.
Uprated clutch, is there a rateing i am best going for ? it is used every day so this needs to be practicle as well if you know what i mean i know the limit of the OE one is 300ft-lb and im already over that. What brand is the best to go for and supplyer?
Hybrid Turbo, ok now im lost i have never bought a turbo before so i dont know what i need so how does it work do i need to buy say a PD150 to exchange it for a hybrid PD150 or can i buy one of the shelf? is the PD150 the right one to go for or is there a better option? do they need tuneing once installed as they are VV ones? i under stand about the clocking. again brand and supplyer would help loads.
Singal Mass Flywheel, i understand these just need advice in brand supplyer
any help would be great
thanks in advance Si
Two clutch choices, sachs or helix. You dont NEED a SMF to run a hybrid. Could get a sachs clutch for £700 ish from jabba. If you want the SMF then you migh as well get it as a kit with the clutch. Hybrid turbo can be confusing, but all the big turbo companies do them, turbo dynamics being one big one.
Matt
Edited by matt1chelski
E mailed unit 18 for info and a price all in over a week ago no reply geuss they dont want my money :thumbdown:
just trying to find info on a limited slip diff now
Edited by Si Vxr
just got an email back :thumbup:
Had a peloquin atb diff in my fabia and they are a top mod, quaife are exactly the same so if you opt for one of the 2 just buy whichever works out the cheapest, inc fitting it should be around 1k, another option is the new atb diffs from wavetrac i was reading the theory on these the other day and they sound an awesome piece of kit, but i have no expierience with them, as for clutches spec make the ultimate ones for the fabia but with the exchange rate as it is they work out extemly expensive at the moment
