Heater Motor
Hello All.
How easy/hard is the heater blower motor to get at/remove?
Been following the posts re: heater problems on here.
But am now thinking the motor has packed up, though it still runs, but very slow even on '4' . . .
Think either the motor is duff or brushes have gone . . .
TIA
Lytham2 aka John
Easy.
Unscrew and remove the glovebox and it's right there. :thumbup:
Easy.
WOW! - Cheers for that . . .
John
Check out the series resistor pack too as a this can also give the same symptom if faulty.
It is easy to do as you it is attached to the heater motor and you probably want to remove it anyway.
Mike
Mike
Cheers Mike, when it does work, its soooo slow, from other posts, I thought 12V was applied direct to motor when the switch was in pos. '4' ?? - will look into anyway
john
Edited by lytham2
john
Correct, it should run at full speed in position 4
Just an update.
removed motor this morning . . one motor brush failed, tested motor with external 12V supply . . . now looking to find used motor!
thanks for all replies
Lytham2 aka John
Edited by lytham2
