No rear washer
The pipe will be behind the washer bottle, quite hard to find without moving it
There's two pipes and two motors, when my pipe popped off the only way of putting it back on was to loosen the washer bottle and move it so i could put my hand behind it and push the pipe back on.
The photo Ken posted shows the back of the washer bottle towards the fuel filter that has been moved aside.
The open end of pipe in the picture comes from the pump and is where water comes out of when the rear washer is operated.
What we can't find is the pipe that it should be connected to as we don't know where the pipe is routed under the bonnet.
Niamh
Think it goes into the inner wing just put my hand in and found. It
I thought it might, but we undid the plastic inside the drivers front wheel arch and saw nothing.
Maybe we need to look there again?
Niamh
The rear washer motor wirrs away but no liquid comes out of the jet. Ive taken off the panel in the tailgate - to see if the hose had popped off
(like someone on here suggested)... but its still in place
Are there any other places the washer piping could pop off? My fear is that its accumulating water somewhere I dont know about... emoticon-0124-worried.gif
And due to the winter weather the ground is constantly wet - so I cant even see if makes a puddle under the car somewhere.
It was the joint on the rear left near the cd changer for me too. if yiu push the rear wiper and water accumulates below the cd changer thats yer problem. Look out for the WET PATCH !!
