Is this going to be causing my washer bottle to leak!
I have had a leak coming from my front passenger side causing my washer fluid tank thing to drain within a day, i read what had been posted on here and was told to remove the arch lining and refit the pipe. But that is all i was told! Is the pipe hanging in the picture the one that needs to be fitted back on, if so where does it go?!
That looks like the vent for the battery tray drain or something.
Right, pretty sure it was the one (badly - MS paint FTWemoticon-0136-giggle.gif) circled - which looks intact to me.
Try getting someone to fire the washer while you watch?
Edited by TriggerFish
Probably dripping from the valve on the pump itself if both the pipes are fitted.
My pipe keeps popping in the engine bay below the ecu behind the air intake pipe. Drains the resevoir quickly. Have a look with a torch, you should see 2 small pipes dangling freely. Just pop them back together.
Right got my 12 year old sister to squirt the jets as I poked about. Apparently using the stalk to spray the jets is not as straight forward as I thought!
Nothing outa the pipes that can be seen but there seems to be some water running down whatever metal cylinder is behind those pipes pictured. So airbox area. Will be trying tomo. Thanks so much everyone
There is another connection in the engine bay on the right that runs through into the bulk head, sounds like it might be that! Access is a bit tight (or is on a 1.4), but easy enough to see.
