rere wiper octavia 1.4 2004
Problem.......will not turn off.Removed fuse.Any ideas,switch.....motor.....etc? Octavia 1,4 2004
Edited by bmkeady
Presuming you're got the correct forum, quite possibly water ingress in loom just ahead of LHR lighting cluster, or to motor.
Hello,
I have the same problem on my 1.8T Octy 2004 hatchback. The rear wiper just goes on intermittently. What could bring down the control signal to earth? A faulty switch behind the steering column? Are there any connetions? I already replaced once the rear wiper motor once as it overheated. In order to check the rear wiper switch I would have to remove the steeringwheel, which is cumbersome. Any ideas? The rear wiper switch seems to operate but there is somewhere a short to ground of the control signal, but where?
Could you be more specific what LHR means?
Ken..........Many thanks,replaced pipe connection.......dried out connectors with hair-dryer......sprayed WD40 over area.Wiper motor returned to normal .All ok so far.
Brendan Keady
Brendan Keady
Ken.................only worked for short period.Now its completely erratic will only run if arm is lifted from screen and then erratically.
