Rear Washer Jet
Had a problem last week with the front wipers not working, the fuse was the problem. The washers were frozen. Now the rear one just doesnt work. Any ideas?
pipe has popped off.
Where do i get to the pipe to re-attach?
cheers
Open bonnet and look past engine block to bulk head, easier if you get someone to try and wash the window... Just push the pipe back together ;)
The pipe coming off seams to be a regular thing, any one know of a way to cure this, or is it just another design feature of the car??
I think it's actually a design feature. It prevents the pump from burning out and the plastic pipes from splitting. It happens to both our Fabias quite regularly. (fixed both yesterday).
There are 4 places it normally comes off. Apogee wrote a great guide, and you can find a link to it in the sticky. The bulkhead connection is the most common, if not try behind the rear passenger seat.
Edited by Jim H
Its back on, but now it just splays up rather than following the wiper. Any ideas?
It should just spray upwards, it shouldnt follow the wiper.
