Uneven Tyre Wear
Car is going into the dealers tomorrow for a look. The two front tyres are wearing heavily on the inside shoulders. The tyres are Michelin Pilot Exalto's and the insides are nearly bald after only 7000 miles. The car hasn't been lowered and the only mod is a set of 312mm brakes on the front. Any ideas what could be causing it? I also get a clunking from the suspension when I turn at slow speeds on rough ground and sometimes on roundabouts. Could this be drop links?
Thanks in advance
Martyn
Also who do I see about a name change?
Thanks in advance
Martyn
Just worth a check, have you a broken spring ?
Radiotwo
Thanks in advance
Martyn
Im gonna say tracking for the tyre wear, maybe somebody hit a curb and put it out or bent a wishbone? Good luck with whatever it turns out to be :thumbup:
front console bushes ;)!!!
ask them to uprate to the solid bush from the ibiza cupra
About 2 years ago I slid off the road into a grass bank which did buckle an alloy and I changed the track rod end just to be sure. I am expecting something like a wishbone needing to be changed. It's weird that it's both sides though.<br>
Don't suppose there's a part number about for these? I could get them and they could fit them
