17535 - Fuel Trim: Bank 1 (Mult): System too Rich error
Hi all, my CEL light has come on and I get the following error show up on VAGcom:
1 Fault Found:
P1127 - 35-10 - - - Intermittent
Any suggestions on what it could be? I've cleared it once but it came back.
I replaced the MAF about 11 months ago and doing a block measurement on 003 gives normal looking readings.
Hope someone can help!
boost leak? Have you checked all your pipes?
I'll check that this weekend - thanks for the suggestion Mike :thumbup:
I had a similar error but too lean when I had a boost leak.
+1
I had the same as rob. To lean with a vac leak.
Thanks Rob & Si.
What turned out to be the cause of your leaks in the end? Is there a simple way to troubleshoot (e.g. follow piping from the airbox or turbo etc.)?
In my case my aftermarket TIP wasn't fitted properly (by me) and had popped off the turbo.
I just followed the pipe work and tightened them all up and I'm assuming 1 must have been loose as it cured it :thumbup:
Thanks again all of you - I'll give it a thorough check over the weekend. I have an unfounded theory that it's related to the extreme cold we've had recently, maybe it's caused a pipe to shrink and slide off slightly or something like that...
