Slow engine warm up
Hi,
I have a 2010 Octavia Estate 1.4 TSI which takes 5 miles driving from cold to reach normal operating temperature. Any ideas as to what may be the cause of this(thermostat stuck open?). Or is this normal?
Grateful for any suggestions.
In this weather its takes about 10 miles for my diesel to throw out any useful heat.
Its a sign of the times that as engines get even more efficient that there is less energy used for the creation of heat for mere passengersemoticon-0124-worried.gif
My 1.8 TSi takes about 5 minutes from ignition to warm up, currently these days in the morning is around -10C.
I have been told it is the car!! It's been taking me about 10 miles to get the car up to temp in this bad weather. This doesn't help at all when trying to defrost the windscreen.
Good Luck
I can confirm this. With TDI PD in my Octavia on -10C it needs at least 10 miles to warm up and to start heating the cabin.
My heater works fine. The temperaure gauge can take up to 15 miles to reach normal when driving in -10C or so.
5 mins is about right, my 2.0 vRS is similar in terms of the temp gauge needle hitting the middle of the dial. The new 1.4tsi has a good reputation of being a very efficient engine in terms of power output for energy used, and as heat from an engine is wasted energy (bit like the old fashioned lightbulbs) then the fact that it takes a bit longer to get hot is actually a good sign in terms of your fuel economy.
Thank you all for the replies.
It seems that slow warm up may be the norm in this weather, but even now that the temps. are in the plus zone, 5 miles to warm up still seems excessive. I'll speak to main dealer and see what they say.
Thanks again
Thanks again
I managed to speed my warm up time by getting a HEKO grill cover but use cardboard as they did years ago when not wanting cold air to enter radiator area. :D
I have no problems with mine. Takes 5-10 mins for gauge to get to temp.
But i put the climate to max windscreen and it is clear in no time.
