130 turbo on a PD100
Can a 130BHP turbo be fitted on a PD100, and if so will it make any difference with a custom remap?
Will it be easy to fit?
Certainly would have thought it would fit - sure Ross would be able to confirm.
The 130 turbo on the vRS is a KKK turbo whereas i think the pd100 fabia has a garrett vnt15 - perhaps I am wrong. Should be able to swap though.
You should get higher sustained boost so power could go up so long as injectors can flow enough fuel as they are smaller than on the pd100. e.g my injectors were flowing at maximum capacity on my pd100 with Jabba map at peak power.
:thumbup:
