Removing door cards
hi, How do you remove the front and rear door cards off a Fabia?
I looked at the front passenger's and removed the two screws at the bottom and the one behind the blanking plate by the release handle, I also remove the three inside the handle/armrest but the card is still stuck fast. I didn't want to pull it too hard and risk breaking anything.
Cheers.
I'm pretty sure someone has done this before and posted a how-to... try playing around with some search keywords and see if you can find it. It was probably to do with changing the speakers, if that helps... :)
:wave: it was me :D
Front door card removal detailed here
If it's for an ICE-related task, do have a scroll in there. I've posted other how tos with pics, but others have even more inspiring designs well worth looking at ;)
There's three, not two, torx bolts at the bottom of the door card - might be one of those? Sounds like you got all the others - You then need to tease the card off, starting at a corner, and pulling until the poppers all release. :D
I don't know what the 'poppers' are like here, but on the rear window brake light housing, they are very tight. When my dealer took one out of a showroom model to check the bulb unit (I needed a replacement), he broke it!
Cheers, Its all useful. :)
Hopefully I'll give it another go tommorrow providing the weather is good!
I'm planning to add some Dynamat Xtreme and make some plans for changing the speakers.
