Help Annoying leak/drip above rear seats
Well resolved 2 out of the 3 leaks (membrane in door was not sealed at the bottom and pin hole in drain gulley) just 1 more to go.
Im sure many of us have it. The one that drips onto the rear headrest from the trim. Has anyone sorted this or found the cause, I spent four hours sat trying to sort it but to no avail.
Im sure if anyone has they will help out.
Many Thanks
Rear washer pipe or leaking from the ariel base i would say.
Get the headlining off and have a peek.
Jon
:+1:
Plus how is the radio reception? Water ingress around the aerial base could be bad for the amp built into the base of it.
Will have a look should be some signs when I get to have a look tomorrow. Crossing my fingers.
Had a look saturday,no visible signs I will have to take it off a delve deeper.
mbames ill stop by weds am if ok?
Wednesday should be fine.... I'll be in the office from about 0715
