312mm Brake conversion
Hi I have the brakes, calipers, pads and discs, do you also need the longer hoses from the occy? if you dont, what issues do you face?
Cheers in advance
Standard Fabia hoses will work fine :)
Cheers in advance
Got the Caliper Carriers?
Dont need them. dont face any issues.
Hi yeah have the carriers, basically got an occy vrs 2003 fronts, using pagid discs and pads all round also.
Edited by pstar2002
I used the standard ones, worked fine.
I went with the longer Octy hoses on mine - read a few 'stories' at the time on cupranet about the original hoses being a bit on the short side.
Whilst I doubt whether there is any truth in it, I had the longer hoses, and the brakes off the car, so I thought I may as well get 'em on when fitting.
