Anyone with Columbus
Just got back in before and found for some random reason the screen is staying backlit after i remove the key and that has never happened before!
Anyone had the same problem on an FL vRS? I'm confused! :S
Will go off after a bit don't worry. You probably have just not noticed it before... sometimes takes up to 15min. Also once the system has fully shut down and if you are quick enough when you unlock the car you will hear the system kick into action
Thanks for the quick reply :thumbup:
I often get out of the car in the dark and I am certain it's never happened before :S I'm going to go out again soon and have another quick look - don't want to wake up to a flat battery!
If there is anything up with it the car is back at the dealers on Friday anyway for alignment issues :'(
Yeah i did that the first time i noticed it, just don't unlock the car else it'll boot itself up again!
Just been out and checked - it's went off, panic over :giggle:
Thanks for you help though mate, much appreciated :thumbup:
No problem - still strange why it stops on though! Suppose it stops it having to shutdown and boot up if you are stopping and starting a lot.
