ASR warning light
I've noticed the ASR warning light (the one with an exclamation mark inside a triangle inside a circular arrow) has come on and stayed on a couple of times recently. It doesn't happen all the time, and switching the igntion off clears it.
I guess it's most likely to be an ABS sensor on the way out. If so, is replacing it a dealer job, or can I entrust it to my local VAG independent?
Or you are having a real blast in the car :D:thumbup:
