Change front fog lamp bulb RHS on 08 Octavia RS
Hi all,new here glad too be onboard :smirk: I've dne a search on here cant find my answer so sorry if it has been discused before.
My problem is as say's on the title i cant seem too figure out how too change the front RHS fog lamp bulb :( so i would be gald of any help or tips form any of you guy's/gal's
Thank's in advance!!
Yay! Welcome to Briskoda from another Irish vRS driver!! B):thumbup:
You'll find the easiest way is to pull out the RHS section of the lower grille. It's tight, but it will pull out eventually. (& even if you break it they're only about €8 from the stealers!)
Then 'feel' around the back of the lamp for a circular cover approx the size of the lamp itself. This will twist off, and you're in! Detach the power plug (pulls off easily), release the metal wire clip that holds in the bulb, & replace. The bulb is a H1 on the vRS-std models are different IIRC.
In the past I've dismantled half the front/underneath of the car before I discovered this method....... :giggle:
If you've any probs & are near NE Dublin pm me & I can give you a dig out!! I also have VCDS if required-feel free to give me a shout.
Thank's for the reply ill have a lash at it when my wife get's home from work with the car :smirk: ,
Im Limerick based myself SkodaPhile glad too be on board here :D
  • 5 months later...
Hi shodaphile, do you know if there is any adjustment in the level of the fog lamps?
Maybe somebody else can help me, I don't want to distmantle the front bumper if there is an easy way.
Thanks.
