Fabia vRS lights wiring diagram.
Anyone got a copy of it?
My passenger tail light has went after starting the car, putting the lights on and driving about 2 meters, changed the bulb and still not working. The warning light on the dash comes up and I'm looking at the manual and it says the warning light comes on if a light bulb is damaged:
Brakes applied (brake light)
in lighting (low beam and/or rear light).
Its doing my head in and am needing it fixed and hopefully a diagram will give me a clue hopefully, unless someone knows the problem!
Which bulb are you changing? Be suprised how many people change the top one rather than the bottom, also have you used to the correct bulb.
It is the correct bulb, the bottom one that houses the fog lights too. It was at a Skoda garage the bulb came from.
Try swapping side to side to make sure the new bulb's OK
Edited by DRJ
