Help - urgent! Disconnet battery without setting off alarm
Sorry, in a rush and no luck with search.
I want to disconnect my (fully charged) fabia battery to trickle charge it for a few months while car in storage. However I need the doors locked before I disconnect the battery. This means the alarm is armed, so every time I disconnect the battery it goes off!
The key fob won't deactivate it, and the manual doesn't say anything about this?
How do I disconnect the battery without setting off the alarm?
Urgent replies much appreciated!
Jon
disconnect the battery then lock the car manually
Cheers Wilcox, sorted now.
The problem was all 4 doors were unlocked, and I knew I couldn't lock them manually without the central locking working. I don't think you can lock the rear doors manually can you?
However then remembered my car is set to only open the drivers door on first click of the fob, so just did that, disconnected battery then locked it with the key.
If the ECU was set to unlock all 4 doors on first press of the fob though, not sure how you'd lock them all again with no power.
cheers
Jon
glad its all sorted now :thumbup:
For future - if you lock it with the key in the door, then lock it a second time with the door, I think it disables the alarm, and deadlocks.
Doesn't disable the alarm...
You keep telling me this - one day I'll actually remember! :giggle:
