Heater control problems
Hi
Have just aquired Fabia and discovered heater control which adjusts airflow direction is faulty- always blows on f/s passenger feet , nothing on driver side but face and screen work as should. Any links/help regarding how to get it all apart and fix much appreciated.
thanks for the reply-will try taking stereo out first- looks a lot easier. will let you know...
just fixed airflow problem, guess what, someone had put the air filter cover on backwards leaving a large gap at the front hence the draught-always worth checking before taking the whole thing apart cos its L shaped and can go on backwards v easily. Thanks for your reply as i stil had to take glovebox off to find it.
regards
Chris
